ICS3000 Automation Manager Valve high pressuring
Im inconsistantly getting the following interruption in the audit trail while running an ICS3000 with AS50 autosampler.
{AM_HP2} High pressure valve 4 error
It will stop my batch and then clear the error ~2 seconds later. I'm using a 10 port High pressure switching valve, is anyone aware of a pressure limitation or setting in the commands for these instruments (specifically the automation manager) or aware of any fix for this issue?
The pressure in the chomatography is normal without spikes and no assignable cause can be identified. Any help would be much appricated.
This is very late - and I hope you have resolved your issue by now - but in the server you can usually define the severity of errors. Perhaps this can be made a warning error rather than a stop one as it seems to self correct?
