Select permanent gases
Posted: Tue Oct 22, 2013 4:45 pm
Good afternoon
in order to work in steam reforming, I need to measure the following components: H2, O2, N2, CO,CH4 and CO2
I have a GC Agilent 7820 A GC. I consulted to the company, and they suggested me to use the "Select Permanent Gases" capilary column package (http://www.chem.agilent.com/en-US/produ ... fault.aspx).
It consists in a combination of a kind of a Porapak Q, and a molecular sieve capilary columns, which are optimised to measure in paralell all the above mentioned compounds
Does anyone have experience with this system?
should I buy it?
thank you very much
Ángel
should I buy it?
thank you very much
Ángel
