HP-Agilent 1100 "Care Package" - Spares for sale -All sold!
Posted: Tue Oct 22, 2013 10:14 pm
Folks,
The company for which I work recently bought a pile of equipment and goodies at auction from OSI Pharmaceuticals and in that pile are a few spare parts, both new and used, for an Agilent 1100. Being that my LC's are Waters units, I have no use for this stuff and would prefer that it go to a good home rather than a landfill. I'm selling as a single lot and if there's no interest here, I'll put the individual bits on eBay, though I would prefer to sell here.
Please note that I make no warranty whatsoever for any of this material. Once you buy it, it's yours, period. I have no means to test this stuff, though I am an experienced chromatographer and will be happy to send photos of any pieces you're interested in.
The list:
G1103-60001; Tungsten Lamp Assembly for Agilent G1315A/B/C/D and G1365A/B/C/D diode array detectors, and 8453A diode array spectrophotometer ; Qty: 4; 3 are new & in sealed boxes, one box is open but lamp appears new & unused.
G1311-60009; Purge Valve Assy for 1050/1100: Qty:1; New & in sealed box
01018-60025; Solvent inlet filter, SS: Qty: 2; Notes: One new & sealed in box, the other appears new but is in an opened box
5041-2168; Glass filter, solvent inlet, 20 µm, for Agilent 1200 Infinity Series; Qty: 2; Both new
5063-6586: Piston, sapphire, for Agilent 1100, 1200, 1260, 1120, 1220 Infinity pumps: Qty: 4; 2 appear new, 2 appear used but clean.
G1312-60010: Active inlet valve for 1100; Qty: 1; Used, appears clean - operating condition unknown
G1312-67305: Connecting capillary, stainless steel, 0.17 mm, 60 cm, used as outlet capillary or pump to injector; Qty: 1; New
G1313-87305: SS Tubing, 180mm, 0.17mm id; Qty: 1; New
G1316-87300: Capillary, stainless steel, 0.17 mm id, 90 mm; Qty: 1; New
01090-87305: Tubing, stainless steel, 0.17 mm id, 130 mm, with fittings; Qty: 1; New
G1315-87311: Capillary, stainless steel, 0.17 mm id, 380 mm; Qty: 1; New
5062-8517: Frit Adapter 3mm/4 pk: Qty: 0.75 - 3 of the 4 frits are present; New
I think 0.2X retail cost for the new bits with the used ones thrown at no cost is fair. $400 shipped anywhere in the USA.
Please email at christopher dot m dot judd at gmail dot com if you're interested.
Cheers!
CJ
The list:
Cheers!
CJ
