Ask for help:the material of mass spectrum of gcms
Hi all
The TMS-Derivatized aliphtic acids mass spectrum is following:ions 73,75,117,129,132,145(base peak) ,207,
253,281,299,341,355. molecular weight :370. Formular:C22H46O2Si I hope a accurate material is interpreted in detail
thank you
Are you asking for confirmation that the peak is the trimethylsilyl derivative of nonadecanoic acid?
,nonadecanoic acid is not right,especillly for ion 253,281,299(all relatively high).
Users browsing this forum: Semrush [Bot] and 1 guest
