huge ghost peaks
see huge peaks of decamethyl cyclopentasiloxane, octamethyl cyclotetrasiloxane,docecametyl cyclohexasiloxane,
Are they column bleeding, how can I get ride of them? Thanks a lot!
Are there any septa particles in the lower part of your injection port? If a piece of septa falls down into the injection port sometimes the solvent from the injection will extract siloxanes from the septa and make such peaks.
I figure it out. it is not in the system. probably from the cap.
it is in the
