Importance of Controlled Room Temperature
Posted: Thu Nov 14, 2013 4:52 pm
For a UPLC-MS/MS system, how important is it that the room temperature is controlled to within a +/-5C range? If room temperature exceeds this range, what can an analyst expect to see in their results?
Some additional info about the UPLC-MS/MS system - gradient mobile phase, column at 40C, chemical residue analysis, ... let me know if you need additional info. I mainly just want an open discussion on the importance (or lack therof) of temperature control for a UPLC MS/MS system.
