Detect formic acid in acetic acid
I need to determine formic acid as impurity in acetic acid, and I would like to use MSTFA as reagent. Anyone ever done on this? Or is there any other method? Thankz....
Very straightforward analysis if you have a TCD detector or a helium ionization (Discharge Ionization) detector Be aware of bare metal surfaces in any detector however.
FFAP capillary works wonderfully. Buy it from my company or a competitor. Please note that formic acid elutes AFTER acetic acid when injected as free acids. Strange but true.
best wishes,
best wishes,
If troublesome by GC, consider HPLC/ion chromatography. Formic acid gives a nice peak.
Most analyts use Ion chromatography or HPLC to measure formic acid. There are many applications among the vendors of IC and HPLC columns.
GC is not the easiest method but it is probably the fastest.
reaards,
reaards,
thankz for the help
Users browsing this forum: Google [Bot], Semrush [Bot] and 8 guests
