Can room temperature fluctuation cause retention time shift?
Posted: Tue Dec 17, 2013 4:00 pm
Hello everyone
I have just had a discussion with my colleague about shifting retention times. Fact is: She is running a program for quite a while now, and we see retention time shifts of about 1.5 min from one to the other extreme. There are hints that this is correlated to GC measurements running or not running, GC heating up the room by about 6 °C (No, we don't have a good room temperature control).
We use a column oven (set to 25 °C), therefore I don't believe in the temperature fluctuations as a cause (literature says that "his can obviously be avoided when a column thermostat is used", http://ict.ups-tlse.fr/plateforme/HPLC/ ... de_Q_A.pdf).
Anyway, I don't have a better explanation.
Yes we checked: performance of the column oven, pumping rate, gradient mixer etc. The column is also OK, judging from a reference solution.
Any other idea?
Kind regards,
Jörg
Any other idea?
Kind regards,
Jörg
