Imidazole-2-carboxaldehyde purity method
I need to develop purity method HPLC/GC for above compound.
The problem on HPLC is retention of that material
I 've tried reverse phase C18( retention on solvent front) low and high pH
Then I've tried hillic with the same lack of retention.
Thanks for any help in advance
M
Maybe this will provide some help:
http://www.atmos-chem-phys.net/12/6323/ ... 3-2012.pdf
This compound is polar enough that retention in HILIC shouldn't be a problem. Please supply the following details:
1) The column you're using.
2) The mobile phases
3) The composition of the solvent that the sample was in when injected.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
