EMPOWER 2: Cannot save results after manual integration
Hi all -
I can no longer save results after performing manual integration. When I go to the File > Save submenu, the Result option is grayed out (as are all the other options). Does anyone know what can cause this?
I have the same problem when trying to Monitor or Setup Instrument Methods in the Run Samples window. When I select the Instrument Method from the dropdown menu in the box, the Monitor and Setup options are grayed out (only Edit can be selected).
Thanks for your help.
Sounds like someone may have changed user permissions.
Hello
Just ask Admin to check your account privileges.
Regards
Tomasz Kubowicz
Hi kubowicz.tomasz
another possibility: Is there a "Read Only lock" or "Full Lock" on the project?
Best regards
a.wombat64
a.wombat64@googlemail.com
