what do yo weigh the most when buy a sencond hand hplc
does distributer usually give out Qualification and Performance Testing results?
If the distributor is reputable, you should be able to ask to have detector noise and drift specifications verified, and if they match those reported by the manufacturer. For me personally, everything comes second until I am sure the detector is working and will suit my needs.
Don't expect a 2nd hand instrument to be trouble free for years... most of these distributors do not go through the trouble of changing consumables such as pump seals, check-valves, pistons, lamps, flowcells, needles and fittings. These are all things you should be prepared to replace after a few months usage.
Most importantly you want to make sure that the software is compliant for your purposes.
Previous experience with that system.
Comprehensive documentation(and I don't mean user manuals).
Local support.
Local support.
Local support.
Thanks all for your feedback!!!
Local support.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
