Tablets: dependence of peak height/area on crushing or not
I have a tablet with two well-distributed APIs.
When I dissolve the entire tablet as it is, I get higher heights/areas for API 1 than when I crush the tablet before dissolving
At the same time, I get lower heights/areas for API 2 for non-crushed tablets compared to the crushed ones.
Does anybody knows such phenomenons as well as a solution?
Florian
Sounds like you have both a solubility issue with one API and a sticking problem with the other.
I'd be inclined to find a LC-friendly solvent capable of fully dissolving both APIs in the tablet matrix and avoid crushing the tablets. Use a number of whole tablets and a larger vessel for your sample prep.
I'd do what DR suggests.
Why crush tablets if they dissolve? Extra step, chance of cross contamination, volatiles loss, etc.
In total there are 8 users online :: 2 registered, 1 hidden and 5 guests (based on users active over the past 5 minutes)
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 5 guests
