regarding hexane sulfonic acid
May I know the best pH operating range while using 5mM Hexane sulfonic acid. are there any possible additives to be used along with HSA for a better peak shape in HPLC
- tom jupille
- Site Admin
Given that sulfonic acids generally have pKa values < 0, the choice of pH will be determined by column stability and analyte ionization rather than by the ion-pair reagent.
As far as peak shape improvement is concerned, there is nothing about hexanesulfonate that suggests a particular additive, so it would depend on what it is about the analyte that is causing the tailing (insufficient buffer? poorly controlled ionization? multiple conformers? etc.).
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 12 guests
