Accela pump to PAL autosampler connections
Does anyone know the pin-outs between the PAL Interface 1 DB15 connector and the Accela pump D-sub25 connector? The manuals lack so much information these days. Nothing states signal in or signal out, TTL or CC, voltage or time.
Also is there a reset for pump stroke count on the Accela?
I have just set up an LC-UV system using a PAL and Accela.
The PAL manual has all the pinouts in the back. It can be found here: http://www.palsystem.com/fileadmin/temp ... .pdf&user=
The only connection between the PAL and the pump should be contact closure.
The PAL, Pump, and Detector should all be separately connected to the data system. At least that's how we have it set up and it works great.
Hope this helps!
Users browsing this forum: DuckDuckGo [Bot], Semrush [Bot] and 7 guests
