PBDE determination by USEPA 1614
Could someone share your lab experience in handling PBDE analysis by USEPA 1614 ?Any tips and tricks, in particular for BDE209 and other higher brominated DE? Thanks
I don't run that method exactly but I do analyze BDE209. What is your specific analytical issue with that compound? Phenomenex just recently released an application note on it's analysis using their new Semi-Vol column. It dramatically, according to their app note, increases signal and S/N for BDE209. I ordered a couple different dimensions of it but I haven't used it yet. https://phenomenex.blob.core.windows.ne ... 057d5e.pdf
I found BDE209 sensitive to injector and column temperature greater than 270°C and thus I use a PTV inlet for ramped temp volatilization. Also On-Column or On-Column-like injections can increase sensitivity of BDE209.
~Ty~
What are your concern or problem faced?
for detailed tips, I need to know your instrument and column.
Sean Wang
General Separation Technologies, INC.
625 Dawson Drive, Suite A
sean_w@gs-tek.com
Newark, DE 19713 USA
Phone: (302)521-6325
Fax: (302)737-4547
In total there are 20 users online :: 0 registered, 0 hidden and 20 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 20 guests
