MSD E.02.02 glitch
My sample log table wont retain sample weight, internal standard weight or density information when I prepare a sequence. I can run the sample and put the information in after the fact to obtain my report.
I've been unable to identify any settings that might cause this. It is a new installation of MSD on a new installation of Windows 7 Pro.
If there's any other information that I could add to help clear up this issue, I'll gladly post it.
I'd love to know if anyone else has seen this?
I haven't encountered this but you could try installing Service Pack 2 for that software revision. It can be found on the Agilent website. Hope that helps!
I'll give that a try. Thanks. :)
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 1 guest
