should end users be able to edit Custom Fields?
GxP application
I guess it would be up to how your system was validated and what is in your SOP's for how the system is to be used. I would say that if custom fields are used and not validated then a 100% manual check would probably be prudent.
Users browsing this forum: Semrush [Bot] and 1 guest
