Hitachi fittings?
I have inherited a Hitachi L-6200 pump that we need to use for a project. All we need is the pump for a non-chromatographic application.
It's running, but we don't have any fittings and I need to get the 1/16" line attached to the exit from the drain valve. Of course, this is the high pressure side.
I've struggling with finding the fittings (nut and ferrule). ASAP Analytical is looking. Most of the supply houses list other manufacturer's parts, but not Hitachi. Is the Hitachi fitting a standard size? Would something like a Rheodyne fitting work?
Use a PEEK fingertight fitting , it should fit to output port.
Contact Sugiyama Shoji (www.sugiyama-shoji.com) in Japan. They can supply any fitting you want for Hitachi instruments.
PolyLC Inc.
(410) 992-5400
aalpert@polylc.com
In total there are 7 users online :: 3 registered, 0 hidden and 4 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 4 guests
