How can i know the flow cell in FLD is contaminated
how can i know the flow cell in the Flourescence detector is contaminated , if there is any problem in flow ,can effect the samples results ,if so how can i clean the flow cell ..?
Take a Raman spectrum of pure water , and check the S/N ratio according to device specifications.
You may clean the flow cell by passing first water , then IPA.
After cleaning with IPA , pass water again before proceeding with mobile phase ( if it is reverse phase method )
In total there are 20 users online :: 3 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 17 guests
