Change Window Title in Chemstation
Hi, i´m writing a macro for extracting ion chromatograms and displaying them in 3 Windows. Is there a way to change the Window title, from Window #1 in something else?
Thanx, Melanie
In the GC ChemStation you can use the following:
SetWinTitle (Window number),(Window Title)
Gasman
Here is more information from the Agilent help files
SetWinTitle
Gives a title to a display window.
Group
View commands
Syntax
SetWinTitle WinNum, Title
Parameters Type/Description
WinNum Number of the window to receive the title.
Title String for the title.
Discussion
The title is set in the display window if it is there. The title is kept in the WINDOW table of _CONFIG[1] for future use for the window.
Return Variables
None
Copyright (c) 1990-2002 Agilent Technologies
Gasman
I know this command, but i don't find any .reg-file
Which version of ChemStation are you using and what register are you trying to find?
Gasman
Unfortunately doesn't work for E2.00 :cry:
