Chemstations LC: export data to .csv via command line
Posted: Tue May 27, 2014 8:33 am
I'm using Chemstation for LC Rev. A.08.03. To export data (for example integration results or signal data) I use File --> Export File --> CSV-File... to do so.
Does anybody know how to this via command line?
Let's say I would want to export the integration results to C:\hpchem\2\data\username\test.csv
Is this possible and if yes how?
Thanks already for your suggestions!
