help about convert AB .wiff data to mzXML format using TPP
hi all:
I am trying to convert AB.wiff raw data to mzXML format, using Trans-Proteomic Pipeline (TPP) , but it doesn't work, the message showed that •Command is not running,Did NOT kill command. file not found: not created or deleted; what may be the problem ? any help will be appreciated! thanks!
you think you can,you can
While I've never used the program you're using, I did Google the question out of curiosity, and found that AB Sciex has their own program for converting the .wiff to mzXML, called "AB Sciex MS Data Converter". Maybe you could try it instead?
http://www.absciex.com/downloads/software-downloads
Time flies like an arrow. Fruit flies like a banana.
