Chemstation aborts after injection
We have a 1100 Agilent HPLC. It's been working fine, but recently it started aborting the run directly after injection. The logbook says that it is due to an error (but no error information/number). We tried remaking the method and even reinstalled chemstation, but the error persisted! the run is aborted after injection.
Do you have any suggestions/tips to solve such problem?
Set the vial number to nothing for a blank injection, then run the Method, see if same happens.
During a real injection, I'd also look at that moment and see if the pressure drops out.
Have you loaded the logbook from the data folder from the sequence (rather than the current logbook)? I've noticed that sometimes has more information on which module shutdown.
Do you have any modules that are connected by CAN but not in the current configuration?
