How to perform specific absorbance
How can I perform specific absorbance of a particular drug substance? Which solvent to be used? Thanks.
Your compound is soluble in...........?????????
If Methanol is the solvent, run a UV Spectrum to see the maximum absorbance.
Try to use a solvent with a low UV cut off.
That's it.
In total there are 19 users online :: 2 registered, 0 hidden and 17 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 17 guests
