Empower pdf for all chromatograms in sample set
Hello Everyone,
For documentation purposes, I am hoping that there is a way to make a PDF (or any document really) with all chromatograms from a single sample set. Ideally, this report would have one chromatogram per page for each injection in the sample set. Having integration data would be nice but would not be absolutely necessary for my purposes.
Thanks a lot,
Anthony
If you have already made or chosen a report format you like, just close the print preview, right click in a margin and select "Summary by all". Save it (maybe with a slightly different name) and print preview again. You should have the same one page for every injection found in a result set.
If the preview looks good, hit the icon to create a pdf and tell browse to where it should wind up.
DR
Users browsing this forum: Google [Bot] and 5 guests
