Robustness test for Related Substance
Posted: Mon Aug 25, 2014 4:42 am
Can I use Change in Detector for Robustness Test? Is it okay if I'm going to use PDA detector first and changing it into 2487 UV/VIS detector? Thanks.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
Of course you can! This way you will have established method robustness over both UV-detector models. Especially in the future as you might need to transfer the method to another laboratory with PDA/DAD detectors only.Can I use Change in Detector for Robustness Test? Is it okay if I'm going to use PDA detector first and changing it into 2487 UV/VIS detector? Thanks.
