FID Not responding
Posted: Tue Aug 26, 2014 12:18 pm
Agilent 6890 Series GC with FID and TCD showing Front detector not found (FID). What can be the possible cause. Please help
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
This may be the cause. In the display panel in front of the GC it is showing Temp Not installed. If this is the reason is it required to buy only the heator sensor assembly or any other items?Kindly helpTemperature sensor is open circuit ( broken )
Did you solve the problem. I encountered the same problems. And we have same issue here.Agilent 6890 Series GC with FID and TCD showing Front detector not found (FID). What can be the possible cause. Please help
