brookfield viscometer calibration
Off-topic conversations and chit-chat.
Does any body know viscometer calibration?
Which steps include in calibration?
Try looking at the user manual. I know you can download Brookfield's (if this is your manufacturer) from their site. Even if you have an old model or non-Brookfield model viscometry hasn't changed too much lately and you can probably pull a calibration procedure from a newer model's manual. Typically you want to test your spindle(s) you will be using on samples against viscosity standard(s) in the range. I am by no means an expert on viscometry but I hope this can help you.
Thanks scothy.
