BTX column
Hi, may I know what or which column to use to separate BTX with a high concentration of sulfur gases. I am planning to detect BTX on ppb levels so I want to separate the sulfur gases so as not also to compromise the system due to it.
I know we would use a PLOT-Q or for this, which wouldn't completely separate everything, but we would also use a FID which should give you the detection limit you require
