ICS2000 columns cleanup
Posted: Wed Oct 08, 2014 4:46 am
I performed a columns cleanup (AS-11-HC guard and separator) followed the instruction in the manual, to solve a problem of reduced retention time and floride tailing. The cleaning solution I used is 200mM in 80% Actonitrile. It didn't help. Any advices?
I also found that it took so long (>1day) to bring the background to be less than 1uS after the cleanup. Is this normal?
-Aster
Here are chromatograms showing my problems with retention time.
https://www.dropbox.com/s/seimgjp0j7pn4 ... e.xls?dl=0
Thanks!
-Aster
Thanks!
