Analyst 1.6.2 and DCMSLink
I'm running a API4000 and Ultimate 3000 controlled Analyst 1.6.2 and DCMSLink. All data is written to a network share. My problem is that I experience random stops at my system. The DCMSLink log says "Failed to set properties "AnalystSync.DoInject"" and the system stops. We have a similar system running, just using an API3000 instead and have no problem. The computers are clients and Window 7. I've been in contact with our local IT-department, Dionex and Sciex and tried the most. I'm running out of ideas and wonder if there's anyone out there that experienced anything like this?
We have the same problem with an API5000. It's either "AnalystSync.DoInject" or "Cannot pause sequence". Did you manage to solve the problem?
No, I didn't solve the problem. The only way is to replace the instruments, which we did autumn 2016. Analyst 1.6.3 does't help either. May be Analyst 1.7?
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 15 guests
