Chemstation Report Style question
Hello, I have a question about organizing my chemstation report layout using compound groups. Basically what I want is the following: I would like the peaks within a compound group to be arranged by retention time. Attached is an image that explains my problem. What I want is the Aroclors to be arranged in the order of Arolcor A. Aroclor B, Aroclor C, etc. but instead they are all out of order. Does anybody have any ideas? [img][IMG]http://i1372.photobucket.com/albums/ag337/pacerlaser/PCBreportlayout_zps3ff349fa.jpg[/img][/img]
I've got no idea how to help with your report. But I learned on an automotive board how to make your photo visible inside your post. You paste the .jpg link in-between the "code" brackets that show up with cursor line in middle when you Click Img box here.
I have not used this in a while, but I believe you have to make sure these peaks follow the retention time order within the quant database. If this is the chemstation I think it is, look up the getcompound and putcompound commands - these can help you rearrange stuff without needing to create new entries.
