HILIC of Nucleotides
Our lab does routine analysis of sugar nucleotides, primarily using ion-paring reversed phase methods. Although this works, it's less than ideal, especially for LC-MS analysis.
Recently hydrophilic interaction chromotography has been suggested to us for use in separating the highly polar NTPs, NDPs, NMPs, & NDP-sugars which we work with. Does anyone have any experience with using HILIC in separating nucleotide-based compounds? From my review of product brochures and literature, it seems that HILIC is aimed more toward resolving basic compounds, versus acidic phosphates.
Thanks.
I have developed a method for nucleic acid bases separation by HILIC. But sugar and phosphate were no longer present and we separated only purine and pyrimidine bases adenine, thymine, cytosine, guanine and uracil. I don’t know if it would work with a sugar based nucleotide, but I used a Luna aminopropyl column from Phenomenex with
A: Acetonitrile
B: HCOONH4, 10mM pH3,0
With an injection in 100% A followed by an elution by a shallow gradient of B.
Have you thought trying a reversed phase column with increased polar retention (low carbon load, polar embedded group...)? That could allow removing of ion pairing reagent and give you MS compatibility.
Hope this help
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 9 guests
