Any way to enhance molecular ion for GCMSMS analysis?
I am just starting to develop some methods for GCMSMS and am wondering if there is a way to get less initial breakdown of the analyte in the EI source so that you have greater molecular ion to work with going into the collision cell.
I have tried lowering the uamp current to the filaments and am starting to play with reducing from -70ev but not really seeing any shift in abundances. Is there any trick to this or am I just stuck with a lot of fragmentation in the source?
Cooling the source might help a little or what about CI?
Well I pushed for CI when ordering the instrument, but ended up getting one without it. Now I wish we had.
Working on a method for Methamphetamine without derivatization, seems I can get a little better sensitivity in SIM than I can with MRM, just more background is present. The molecular ion is probably less than 1% abundance so the molecule breaks down pretty well before hitting the collision cell.
James,
How low have you dropped from 70 eV ?? You may have to go quite low, e.g 20 eV to get a meaningful mol. ion. If you have a solids probe, this would be easy to do stepwise.
Since your M+. is at m/z 149, and the fragments are obviously lower, you could distort the tuning (I assume QQQ) to enhance the low mass end; you don't need sensitivity above ~m/z 175 in either Q1 or Q3.
JMB
James,
JMB
I think I went down to 30ev, I may try lower and see what happens.
