Cleaning Columns?
I'm taking a chance on some used columns ($40 vs $700!), and wonder if there is a reliable way to clean them.
They're Waters Symmetry C8 4.6x150mm, mobile will be MeOH/AcCN/water/HOAc.
Any good ideas?
Thank you!
If you are mentioning about buying used columns around $40 , please also consider blocked frits , void packing , leaking connections , precipitated buffers inside the column etc.
If you are lucky , and get a column in good condition , then try 20% ACN + 80% water first , and continue with 100% ACN.
Reverse the column during washing , to prevent heavy contamination run into the column.
In addition to Uzman please disconnect the detector when rinsing your column.
Hello All,
This article is So Good, I've posted this on LinkedIn as well:
http://www.pharmtech.com/pharmtech/data ... rticle.pdf
Thank You, LC-GC magazine!
MattM
Users browsing this forum: Google [Bot] and 13 guests
