Alternative method for Gas chromatography
Hi
I have test sample of mixture of organic solvent and organic acid( example: butanol, ethanol,acetone, acetic acid and butyric acid etc) I want to measuring the concentration of particular substance and also identify the chemical component.
Can anyone suggest a alternative method to test the sample apart from using Gas chromatography
Thanks in advance
Hariprasad
NMR ?
In total there are 30 users online :: 0 registered, 0 hidden and 30 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 30 guests
