what can be run in gc like big hump
Posted: Fri Nov 21, 2014 6:45 pm
so you will not see any peaks but a big hump.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
so some food grade fat can also do the same trick?If all you want is a be hump-o-gram try motor oil. If you want a hump with spikes on it try diesel.
No, triglycerides like food grade fat will typically just give three or four peaks by gas chromatography. And specialty high temperature columns must be used typically for these.so some food grade fat can also do the same trick?
