Agilent 1100 with DAD detector
Does anyone know how to save/print the UV-Vis spectrum for the peaks in the chromatogram?
Without the software ? Not possible.
Hint: depends on the software you use for reprocessing chromatographic data. Try to look in Print and Save menu positions.
We copy and paste into Wordpad, Word, Paint, etc. then print.
The software is ChemStation. What exactly do you copy and paste? I guess I am not sure in which file format the spectrum data is stored and how it can be manipulated to get the spectrum.
Thanks!
In Chemstation the "Clip" command copies the contents of a window to the clipboard. Look it up in help to get the syntax.
In LC Chemstation, menu item "Graphics", and select "Copy to Clipboard"
Users browsing this forum: Google [Bot] and 10 guests
