Shimadzu GC 17A
Posted: Tue Dec 16, 2014 7:30 pm
I have a method developed in 2000 that used a Shimadzu GC17A. The method uses a 0.32 mm ID capilary column and injects a liquid sample. The method states an injection volume of 0.5 uL and the injection type as "direct inject". Can anyone explain what the injection type, "direct inject", is? Is it the same as a splitless injection? I'm thinking this might be it since the method doesn't list any split ratio. I do not have any experience with this or any Shimadzu GC.
Thanks for your help.
