Waters Automated Dissolution - HPLC system
Has anyone had experience with these systems?
Do you mean the automated transfer module between the dissolution bath (vankel) and the Waters HPLC. If so I did use them in a previous job. It seemed to work quite well and didn't cause many if any problems. A lot less bother than manually prepping or sampling from test tubes...
The system I am looking at is a Hanson SR8 coupled to a Waters sytem. I was curious to hear if anyone had encountered propblems specific to this setup.
J
It wasn't a Hansen model I had used... I'm pretty sure it was a proprietary Waters build transfer module...
