API 2000 where are the tetracyclines?
Posted: Fri Jan 09, 2015 4:26 pm
Dear all,
I keep fighting with tetracyclines;
I managed to set up a method which works perfectly well on a Waters 2695 and Quattro Premier. The column is a from Waters a SunfireC 18 3.5 um (2.1x 150mm) and the mobile phase is water and methanol with 0.1% of formic acid. In this instrument I have no problem with the Rt of the peak nor with the peak shape. However, when I set up this method on a HPLC 1100 from Agilent and a MS API 2000 I am not able to get reproducibility. I though it may be due to sensitivity but I am not able to reproduce the same peak shape or signal intensity by increasing the sample volume. The Rt and peak shapes move a lot more than one min.
The flow rate is 0.250 ml/min and the injection volume is 25 ul.
I will appreciate any idea or suggestion,
Thanks in advance,
Carol,
Thanks in advance,
Carol,
