Autosampler arm releases samples prior to needle seat
Posted: Thu Jan 29, 2015 5:48 pm
I am using an Agilent 1100 series HPLC. The sample arm is releasing the samples from the back row before reaching the needle seat. During an analysis the arm froze in position 100. I shutdown the machine and restarted and reset the injector. It now works except for the back row (i.e., positions 10, 20, 30 ....100). I have reset the injector several times and it has not helped. Any ideas?
