Diquat in oil seeds
Posted: Tue Feb 10, 2015 10:20 pm
Hello, does anyone of you has experience analyzing diquat in chia grains? Currently, I'm trying with a method of Anastassiades, using a methanol with formic acid extraction and then filtration and injection.
We have an Agilent 6460 LC-MS-MS
The column is an Hilic from waters, and The mobile phase is a) 20 mM ammonium formiate pH 3 and b) Acetonitrile
I have tried too with 250 mM ammonium formiate pH 3,7
The problem is that making matrix extraction I only get to see 100 ppb, and I need to reach to 10 ppb. I also evaporate The methanol extract but without succes.
Could you give me some advice? How to make a better extraction
Any help Will be very useful
Thank you
Thank you
