Nomenclature of chromatograms
Hi everybody
An MRM method with three daughter ions produces three individual chromatogram traces. If I display these traces like this:
Is this a chromatogram or a MRM spectrum? How would you call it?
Jörg
(background: I have a discussion with a customer...)
It's three chromatograms!
In writing a report for a client, I would describe this plot as showing the chromatograms from three alternative transitions (or MRMs) for the compound of interest. I would usually only go into this level of detail if (1) each transition had different problems associated with it (maybe one shows multiple other peaks, so I doubt its specificity, while another is specific but extremely weak), and (2) my client was savvy enough to understand what's going on, and therefore (3) I'm encouraging him/her to take an active part in deciding which transition is most appropriate for quantification.
Good luck!
I agree with lmh.
Spectrum are usually do not have a time axis, only abundance versus whatever is being measured such as mass, wavelength, ect.
Once you have mass, time and abundance you have generated a chromatogram.
Users browsing this forum: Google [Bot] and 1 guest
