ICS2000 camshafts lubrication
Posted: Mon Apr 27, 2015 6:39 pm
Could anyone share with me your experience on lubricating camshafts of a Dionex IC? I need to lubricate the cams to eliminate the noise ("whistling" noise) that seemed arising from the pump. Dionex recommends using Nontrop KR 291 lubricant (P/N 2182.2911). However it is sold in 2lb and a few hundred dollars. I think a small tube (e.g. 100g) will be enough for years' of use. Anybody can recommend an alternative grease lubricant for Dionex IC camshafts lubrication?
Many Thanks!
Many Thanks!
