Chromeleon 6.8 / Multiple channel calibration
Posted: Thu May 07, 2015 8:21 pm
I want to integrate and report peaks from multiple different channels. All the help files I have found concern multiple peaks from one channel.
I am acquiring some 25 SIM channels corresponding to 25 compounds and I would like to produce 1 calibration curve per channel. At the moment I have to integrate and do the 25 calibrations manually on excel which is very tedious.
I tried to automate the integration via the QNT-editor, but it seems that the "autogenerate peak table" only integrates the peaks from the active channel, not all of them.
Any ideas? Thank you.
