tightly sealed vials for hexane?
Hi everyone,
I have one question to you. I am working with hexane as a reagent but the vials I have do not seem tight enough so that hexane evaporates in a few hours. Do you guys know any vials which tightly seal hexane? so I can store the samples in the freezer?
Arum
Hi Arum
What vials are you using ?
I use various vials with teflon-faced silicone seals and solid caps - they are all hexane-tight. Caps with holes will allow diffusion through the septum.
Hi Peter,
What I am using currently is (CrossLab cap, screw, 9 mm, blue, PTFE lined) which does not sealed hexane. Hexane evaporates in a few hours at room temperature and I cannot even store my samples in freezer.
Could you tell me more about teflon-faced silicone seals and solid cap, which are all hexane-tight? Where did you order from? possibly Agilent? Is it possible to tell me specific one you use for hexane sealed since I found a few in Agilent website?
Thanks!
Arum
Hi Arun
This is the kind: http://www.sigmaaldrich.com/catalog/pro ... &region=BW which comes in different sizes. I also use similar ones from Restek and smaller ones from Agilent without problems.
Vials should certainly not leak hexane vapour at room temperature, maybe you got a bad batch. Complain to the supplier.
Thanks Peter!
I will look into it and If I have more questions I will ask you :)
Thanks for the help!
Arum
Those green cap vials from Sigma-Aldrich are the best I have used - I try to keep a box or so around for critical stuff.
