Clogged Viper Cables
Hey All,
I've been left a bunch of viper cables that are solidly clogged. As far as I know they've only had LC-MS grade ammonium acetate, water, and acetonitrile to elute oligonucleotides.
I've tried soaking and sonicating them in mQ water. Some with both heads submerged and a few with the other head exposed to possibly let air through and water in.
Unfortunately none of this has worked. Any suggestions?
Thanks.
I would try to flush them (high pressure pump) with isopropanol and/or acidified water (but I do not have any reasonable explanation for that;).
Good luck!
HPLC 2017 in Prague, http://hplc2017-prague.org/
