UV-Vis Chemstation Software
Hi all,
First off, apologies that this is not a chromatography question -- the UV-Vis chemstation came up in another topic, and I thought that this may be a good place to ask.
Anyway, I currently have an HP 8452A UV-Vis diode array spectrophotometer. It came with UV-Vis Chemstation A.08.03, although the computer is starting to show is age. I'd like to upgrade to A.10.01 or B.01.01, both of which support Windows XP. Is it possible to find these versions on the Web? I spoke with Agilent, and they suggested that I contact my colleagues to see if they have these versions laying around, but so far I've not had any luck. Obviously, nothing is "officially supported" anymore, but I thought I'd ask around to see if anyone has this software.
Nick
Do you have email? I will support you.
Agilent CE
What version of HP GPIB card is needed to run a HP 8452 using G1116AA version 10.01 software?
I have a working 8452 and the software, but need the interface card.
I am in the same position with the same spectrophotometer. My computer just died and I need the software to install on a new PC.
Can anyone tell me where the ChemStation software is available online?
Thanks!
Thanks!
http://tinyurl.com/agilentsoft
Thanks!
Yikes! Looks cheaper to just try and repair the computer. Def not paying that much for software I already have.
I have used Agilent GPIB boards available that fit into the computer CPU, reasonable. I have 82335, 82341, and 82350 types.
I can supply replacement media copy of A.10.02 Chemstation, reasonable, since you're already a licensed user. You'd need to use your existing license number. Also A.09.03, A.08.03, A.07.01, A.06.03, A.05, and A.03
If interested, post your E-mail address and I'll contact you and ask you to make a reasonable offer.
Users browsing this forum: dluk and 4 guests
