CMC enzymatic degradation products
Hello everyone.
I will appreciate help on the chromatographic analysis of engoglucanase activity on carboxymethil cellulose using an oligosaccharide resex column (Phenomenex).
The enzymatic assay is preformed using 2%v (w/v) of CMC and I have problems separating the products of the enzymayic reaction.
I use a microbial enzyme and I need to separate the CMC from the degradation products before loading the sample.
THANK YOUUUU :oops:
PAOLA
Is it a method which used to work, or are you introducing it in your lab for the first time?
If the first mentioned, what changed? probably the column?
best Regards
Users browsing this forum: Semrush [Bot] and 23 guests
